Can someone help
Emily.king5537
2
Hiram ga
I was wondering if someone could answer a question for me I bought a 2007 trailblazer LT from a buy here pay here It has 245 60 18s on it (not stock) I had someone give me a really nice set of 265, 65, 18s now I know a little bit about cars but that’s under the hood so clearly there’s a size difference the back go on fine but of course the front the upper ball joint is touching would just spacers for the front work or do I need the lift also i’m not looking to do any off roading or anything just a daily driver, i do like the look of the bigger tires tho
4,027
A lift won't do anything, you'd need spacers to clear the UBJ.
The 265-65/18 are 31.5" diameter, biggest you can go without using spacers is your current 29.5" diameter.
corky
77
Portland OR
You'll need the 1.5 inch spacers for the wheels but you'll probably need a lift so when you turn or hit bumps they dont hit the wheel wells, i have the same size wheels with the three inch lift and if i hit a dip while turning I'll sometimes here the tires rubbing.
Tcwest38
