Got the P1271 and P1280 again, no real surprise. I'm going to perform the following checks (found on another forum):
Check the voltage with the ignition turned on (engine not running). With the meter set to read DC voltages, voltage should be between about 4.9 volts and 5.1 volts.
You check the voltage in 2 places.
(1) between the white/black wire and the purple wire
(2) between the tan wire and the brown wire. You can actually use either a digital or a needle meter to check voltages.
Then check the sensor resistance (there are 2 sensors) with the engine turned off and the meter set to read resistance.
You check the resistance in 4 places.
(1) Dark blue wire and white/black wire,
(2) dark blue wire and purple wire,
(3) Light blue wire and tan wire,
(4) Light blue wire and brown wire.
Here it doesn't matter which wire you connect to the red or black meter probe, just check the 2 wires in each step together. When you press the accelerator pedal down, the needle should move up or down smoothly, should not jump or hesitate at all, as that will generate the error code. You need a needle meter for this.
