This Video Screen Grab comes from a unique and uncommon access of the GM 4.2L Engine "In Situ" after the Body was lifted by Duane and his Crew over at "RealFixesRealFast". If you note in this image...there are Three Grounds or Bonding Straps attached by Eyelets onto the Lower to Mid-Section of the Driver's Side of the Engine Block.
The One that is Circled in Yellow and Red is the one for the Battery Ground Cable Attachment Point:
Observe the Poor Condition of the Battery Ground here... very much due to the excessive Green "Cupric Oxide" or Copper Oxide accretion that will definitely
INCREASE Electrical Resistance in the Ground Cable Copper Wiring and thus... wind up dissipating much of the Battery Voltage as
***Heat*** due to the phenomena called
PTC (Positive Thermal Co-Efficient).
That Fancy Expression translates into meaning that your Electrical System
WILL suffer from a Poor Ground if Copper Oxide prevails at each Ground Connection and along the length of the Inner Copper Wires The Lowered DC Voltage always results from the presence of said obvious Green Corrosion... by literally 'infecting' that Ground Cable and its Steel Eyelet Connector Tangs; and for a considerable length well up inside of the Black Plastic Insulation covering the Ground Cable(s).
Now some Folks may argue against the idea of using any "Dielectric Grease" at these Ground Contact Locations. But Trust Me... The DISTINCTION of using a Dielectric Substance in these places might seem to be counter-intuitive... but most Corrosion of THIS Kind is due to Galvanic or Electrolytic Corrosion caused when there is an Electron Flow between Two Different or Dissimilar Types of Metal... in this case... Cadmium Coated Steel Eyelets clamped to the Copper Cables... and then Bolted up to the "Lost Foam" Cast Aluminum Engine Block. By using a Small Amount of "Dielectric Grease" on the Tang and Bolt or Fastener... it prevents the creation of the Galvanic Corrosion AND YET... still allows for having GOOD ELECTRICAL GROUNDS. :>)
Duane's Video will prove very helpful if you watch it Slow Motion to view areas of the GMT360 Vehicles with uncommon clarity and with an opportunity to SEE things ordinarily hidden from Plain View...
such as locating and removing the Emergency Brake Cables under the Body of Your SUV:
