Hello, I am having an issue that I cannot trace down the source of. I am getting a slight hesitation (about 1-1.5 seconds) when pressing the throttle coming off of a full stop. The idle is smooth, acceleration is fine once the hesitation corrects itself, and it never has acceleration problems once out of a stop. Plenty of power when cruising at any speed, it's only the slight hiccup when starting up from a full stop. This happens whether cold or at operating temperature. Short stops (quick stop sign), it generally doesn't do it, it's more at a stop light when it sits for a bit that it hesitates. I have put about 3k miles since the engine swap, and this has only presented itself in the past few hundred miles. I daily drive about 60 miles round trip, 5 days per week. Vehicle has full power once past the initial little hiccup, cruises fine, downshifts and revs fine, never any lack of power.
Some history:
2003 TB LTZ, 4.2 LL8
Purchased the vehicle with 86k miles with a blown engine. Swapped in an 75k engine. Used original throttle body (OEM, thoroughly cleaned) from blown engine, original PCM, all new sensors (crank, ECT, both O2's, IAT, MAP, etc... All are ACDelco/ Delphi, nothing off brand), did the crank relearn. This model only has a MAP, no MAF.
New fuel pump (ACDelco) & wix fuel filter, fuel injectors (genuine Delphi), fuel pressure regulator (Delphi).
New plugs (ACDelco 41-103), new coils (Denso)
I switched the throttle body with another used OEM, did the pcm relearn (pulled PCM fuses for 2 hours), same result. Both throttle bodies have been THOROUGHLY cleaned. It starts right up every time, no issues there. There are no codes: current or history. It has been sitting since I 2008, all fluids are new, engine was taken apart and resealed /new gaskets, minus the head gasket, otherwise all are new. Fuel system was flushed (had NASTY gas in it from sitting), have run BG 44K and seafoam thru separate tanks to remove anything residual.
I am at a loss what to try next. Idles perfectly fine, though pressing the peddle when in park has the hesitation as well. The only issue is directly from a stop or sitting and idling, never anywhere else at any speed, kicks down and has plenty of power everywhere else. If I his the throttle aggressively from a stop, it happens slightly less, but under normal acceleration it is quite noticable. It has never died, it catches itself before that, but it's still something that needs to be addressed.
Thanks in advance for any assistance!
Some history:
