Today I was replacing the radiator cap and I thought while I was at it I would check the coolant reservoir cap. It fits pretty loosely and I noticed there was dirt around the threads of the reservoir where the cap would go on as well as inside the cap. The guy at the store asked me why I was replacing that cap. I told him I was basically just doing it to do it since I was working on my cooling system in general. That made me think maybe I was making a unnecessary decision but it was cheap so I proceeded. Upon putting the new reservoir cap on, I noticed it fits much tighter and not just by a little bit but a lot. When learning about the system in general, it seems the reservoir isn't ever under a lot of pressure and I read things saying that cap isn't serving any function other than keeping debris out and doesn't have to be a tight fit. Between that and the guy at the store, I'm wondering if going forward, I should ever care about a loose fitting dirty reservoir cap. Wouldn't a cap being too loose be the cause of the dirt and debris and since that's the purpose of the cap, a tight fit would matter? The part listed as compatible for my 2002 Trailblazer is 82594 which is the dorman help coolant cap. However, I noticed it says non-vented which makes me believe there's a vented option. On the back of the package, it lists a bunch of vehicles but not specifically the trailblazer. However, a part search said this is what I would use. Maybe this is tight fitting because it's non vented and my other cap is loose because it's vented? I don't want to build up pressure that needs to be releasing somewhere by having the wrong non-vented cap.
