Abs rear axle
Jon Blaze
48
06 trailblazer4/4 4.2 engine LT 70,100. Problem with left side rear abs stabil track. There is a peice inside the axle im hopeing that someone can help me with. Picture, part number, how to replace, and any other info would be great. I beleive the part is called ABS RELUCTOR. Thanks for your time and help.
jimmyjam
Removal Procedure
  1. Raise the vehicle.
  2. Remove the tire and wheel assembly.
  3. Remove the rear wheel speed sensor.
  4. Remove the rear axle housing cover.
  5. Remove the axle shaft.
  1. Remove the axle shaft seal, the bearing and the wheel speed sensor ring from the axle housing using the J 45857 (1) and the J 2619-01 (2).
Installation Procedure
  1. Install the wheel speed sensor ring using the J 45860 (1) and the J 8092 (2).
  2. Drive the wheel speed sensor ring into the axle housing until the tool bottoms against the tube.
  1. Install the axle shaft bearing using the J 23690 (1) and the J 8092 (2).
  2. Drive the axle shaft bearing into the axle housing until the tool bottoms against the tube.
  1. Install the axle shaft seal using the J 21128.
  2. Drive the tool into the bore until the axle shaft seal bottoms flush with the tube.
  3. Install the axle shaft.
  4. Install the rear axle housing cover.
  5. Install the rear wheel speed sensor.
  6. Install the tire and wheel assembly.
  7. Fill the rear axle. Refer to Lubricant Replacement - Rear Drive Axle.
  8. Lower the vehicle.
catfish520.na
