- Dec 23, 2012
- 197
For a few months I've been dealing with this issue. I had the codes read and it said I had a bad ignition coil #3, so I replaced it. I was good for 10-14 days, then the problem came back. Speed isn't a factor when it happens, but the REP, check engine, and traction control lights all come on and the vehicle dies. After a few minutes typically, sometimes quicker, it will fire back up and only the check engine light will stay on and even turn off at times. I did a check myself on all of the coils by pulling them out slightly to see if the motor sputtered or remains running (which removing each one the motor sputtered) because it was the same type of issue that happened before I changed the coil. I have about 70k on my plugs, and just thoroughly cleaned the throttle body. I tried going to O'Reillys to scan the check engine light but of course my cigarette lighter plug is either unplugged or the fuse is blown so they couldn't read it. Any ideas aside from getting the light checked what this could be that I can check myself? Thanks
