Pads? Or Rotors? Or Pads And Rotors?
l008com
902
Massachusetts
So back around the start of Winter, my brakes started to pulse and possibly grind. I'm a low milage driver and its a long story but I didn't buy coated rotors, so the pads and rotors are the same age and are about 5 years old. I think it was around 2018 or 2019, before the pandemic.
Also, not working in my favor, is that I don't drive every day. Especially in the Summer, I regularly can go 2-3 days without driving.
So today I was changing my oil and rotating my tires. So with all the wheels off, I took a good look at the brakes. And I'm not really sure what to make of it.
There's a lot of rust, as expected. And some pitting on the rotor brake surface. But it doesn't look THAT bad.
As I'm saving the pictures to upload them to this thread, I'm noticing the rear rotors are warn in a few mm. That, plus the severely worn rear pads, plus the BARELY used front pads... do I have a brake bias problem? How would you fix that? Is there an adjustment for it?
It seems like that would explain the grinding. Would that also explain the pulsing? Or is that separate, and just due to rotor age?
Looking at ll the pictures, I'm not sure if I need, pads, rotors, both, or JUST rear pads and rotors but NOT front pads and rotors?
Thoughts?
Here are four pics of the rotors (not 1 pic per rotor, just 4 random pics):
Here's what's left of the rear pads:
And yet, here is what's left of the front pads:
I'm afraid this forum is going to eat my photos again, so here's the same 6 photos hosted externally, just in case:
https://pasteboard.co/pfSe1AnZIFqg.jpg
https://pasteboard.co/cK1TemOqufRc.jpg
https://pasteboard.co/nDKx24iHXqsA.jpg
https://pasteboard.co/g8KfV75lyOuB.jpg
And the pads, rear followed by front:
https://pasteboard.co/7Ikt3KcDQpbf.jpg
https://pasteboard.co/OFhpPNdo3PXx.jpg
l008com
902
Massachusetts
Fun fact, I have the same problem (rear pads wearing faster) on my mountain bike. But for a totally different reason. On a bike, your front brake is doing nearly all of the work under heavy breaking. But once you get used to going fast, you don't really brake much down hills. And bikes are light so you generally don't have to brake to stop at the end, you just run out your speed and keep going. So I don't actually do heavy breaking very much. But what I DO do, is speed scrubbing a lot, to get my speed just right. And that I generally do with just my rear brake.
But I don't have two brake pedals on my truck so that is definitely not the same problem :biggrin:
budwich
2,067
kanata
You need new calipers on the front... they are seized resulting in most of the stopping going to the back... :smile: and of course, discs on the back and probably rotors there also as the existing one will probably cause the rears to wear more rapidly when replaced.
I'd get new coated rotors all around. That rust is bad and will eventually rust under the friction surface and peel it off. Been there.
Do check all your calipers to be sure the pins are not seized. If the pistons were seized, you'd have smoke from the wheel.
Reactions: christo829
budwich
2,067
kanata
Your calipers on the front are basically seized and are not operating "much". This is causing a "pressure redistribution" such that most of your "stopping pressure" is heading towards the back which are working "fine" except that they are being "over used".
Mike534x
938
How does one check a caliper?
The way I've done it was have the truck supported with jack stands on all four corners, and spin each wheel. If it takes muscle to get it to spin, then it's most likely stuck/seized. Other ways would be going off brake pad wear, and if the caliper will "retract" using a brake pad press/spreader tool....or the old school way of using the brake pad and c-clamp. Either way, resistance or it not retracting is a tell tale sign.
If the fronts are stuck, you'll know it if it's wanting to pull to one side when using moderate to hard braking. Becareful with this method, failed control arm bushings will allow the same to happen.
l008com
902
Massachusetts
I'm still not really sure what to do here. I priced out new pads and rotors at napa and its $333, which isn't too bad. And they are coated rotors this time.
But I'm still not sure how to handle the caliper situation. I'm not sure if it's both fronts that have like-new pads or just one side. I've never bleed brakes before so I'm a little nervous about replacing a caliper on my own. But I definitely want to do the pads and rotors on my own. But once I do the pads and rotors, how can I "test" the calipers to know which are good and which are bad?
Last time I did the brakes, I snapped one of the caliper bolts due to very conflicting torque info on the bolt. So when I replaced it, I went around and removed all the pins on all the calipers and gave them a fresh cleaning and greasing. The brakes were noticeably improved after that.
But if I replace the pads and rotors, clean and regrease all the slides, how will I know if they're working properly? Other than waiting another 5 years then checking the pad wear?
budwich
2,067
kanata
As suggested by MIke345x, use a "C" clamp to compress the caliper. You "normally" do this type of technique to remove the old pads anyway. In this case, it is just a test, you only have to tire the tire off to get at the brake unit. Do the "test" (compressing the caliper) on one of the fronts, paying attention to how much effort it takes to compress the caliper a bit. Do the same test on one of the rears. "Compare" your effort. A "frozen" caliper will take more effort to compress than a "free moving" one. Go from your results.
One question would be... how did you change your pads originally? You some how had to compress the caliper FULLY to get the new pads on in the first place.
l008com
902
Massachusetts
Yes last time I changed the pads and rotors, i compressed the calipers with a C clamp and eerything seemed to go fine.
Is there a chance this IS a case of brake bias configuration and not sticky calipers? I ask because I do tend to be a light braker. That is I brake light and early and I don't usually slam the brakes hard unless some dope pulls out in front of me.
And today when I was driving, as bad as the brakes felt during normal braking, if I hit the brakes really hard, I stopped on a dime no problem. Thats why, even though I don't really know much beyond the basics of how brakes works, it makes me wonder if too much rear bias plus my typically very light braking meant I was mostly just braking with the rear only even though the fronts would be fine?
Or is that all just wishful thinking?
budwich
2,067
kanata
I don't know much more in this area. My suggestions were based on the visuals that you provided. The suggested tests will add "data" to that. Just because things were "good" when you did the install "5 years" ago doesn't mean they are good there after. That's called "broke".
In normal braking, one expects more stopping pressure to be exerted on the front since the moment causes things to be "forward". There is valving function (proportional / equalizer) involved so that the system doesn't get impacted by the significant "dip forward" by having the fronts act more than the rears. I think that is part of the master cylinder, but not sure. I don't believe there is any adjustments but I don't know.... others will comment. ABS on newer systems gets involved and that's where I stop... :smile:
From my experience, most people usually find themselves replacing their front discs more often than the rears over time.
l008com
902
Massachusetts
Yeah and my front pads, after 5 years, look basically new. Although I'm going by just one side. I was in a rush when I did my oil change, I wish I had more time to poke around all four brakes while I had the whole truck up on jackstands. Ugh. Hopefully some day soon I'll have time to take everything apart again.
I'd just replace the rear pads and rotors with quality parts, regrease the pins. It's possible the pitting on the rear rotors ate through the pads. The fronts I'd pull the calipers, make sure the pins are free and regrease them, knock off the rust from the rotors and put it all back together. Don't use a wire brush or anything on the friction surfaces of the rotors.
l008com
902
Massachusetts
Update time:
I replaced the rear rotors and pads tonight in my uncles garage. My next house has to have a garage, it's so nice to be able to work in there. I also re-greased the slides but they were all moving pretty free so I didn't do a whole lot.
I then took the fronts apart as suggested and regreased those pins. More about that below... The front pads had at least 50% left, possibly as much as 75%. The rear pads were alllllllmost totally gone. Like maybe 1mm from the wear indicators. The rear rotors also had a pretty significantly deep wear surface. The front rotors were in much better shape, much less wear, the surface didn't look so bad.
But despite all that, I'm still getting strong pulsing while breaking at high speed. But it wasn't all for nothing, there is muuuuuch less grinding now. Basically no grinding now. And with all the slides greased, the overall feel of the brakes is much better. But I'm going to have to replace those fronts I think. Even though it's probably fine to use, the pulsing is going to drive me nuts. And lucky me, napa is still having a 20% off sale 👍🏼
Ok so lets talk about those fronts. Both were identical as far as pad condition, caliper condition and rotor condition. On both calipers, the normal pin was moving fine, but the pin with the rubber sleeve was really hard to move. I cleaned them out and re-greased but that rubber sleeve really makes those pins hard to move.
I'm wondering if I should just slide those little sleeves off and go without?
I'm also wondering if those sleves are what's causing my brakes to be rear-biased.
I'm one of those drivers that generally brakes lightly, far away from the stop, rather than waiting till i'm 8 feet from the stop line and then slamming on the brakes. When I do slam on the brakes btw, they feel great. But light braking seemed lacking (before today's work). I was told that those sleeves reduce vibration, but the person who said this was not really sure about any details.
So this leads me to the following questions:
1) should I do my front pads and rotors to? Like I said, I'm pretty much already decided I'm going to. Although maybe with the fronts, this might be a case where getting them machines down might actually make sense?
2) Should I just remove those little rubber pin sleeves and throw them in the trash? DO they really make any difference? It seems like all they do it make the caliper work much worse.
Looks like about $192 for front pads and rotors at napa. There are some cheaper (but still coated) options on rockauto. Although with shipping, theres not that big a difference.
Those rubber bushings on the pins are to prevent rattle. Yours might have swelled from using improper grease. I don't know if it's really advisable to leave them off. Best would be to replace the pins with new bushings.
Did you have the pulsing before? If not, check the rears again. Did you clean any rust off the axle flange? That happened to me once where the new rotors didn't sit flat on the flange because of raised rust spots. That's why it's also a good idea to coat the flange area with anti-seize to prevent rust and seizing of the rotor onto the flange.
If you did before, then I would suspect the front rotors are warped.
l008com
902
Massachusetts
Oh it was definitely pulsing before, I just couldn't tell before the first repair where the grinding was coming from and where the pulsing was coming from. Although I had a hint the pulsing was the front when I did some heavy braking on an off-ramp and got some jeep-style death wobble :biggrin:
Regarding those rubber bushings on the pins, how exactly do they prevent rattling? It seems like all they're going to do is slow down half of the pad, causing uneven pad wear by design? Also how come the rears don't have those? The rubber didn't look "swelled" at all but I didn't have mine and another unused one to compare it to.
I dunno. Just what I had heard here and there. Maybe just puts some drag on it to keep it from moving around?
l008com
902
Massachusetts
So after googling around a bit and hearing what others had to say, I'm going to just remove those rubber sleeves when I do my front brakes this weekend. I think it will work great, and maybe this will improve my brake bias a bit while lightly braking, not putting everything on my rear brakes.
l008com
902
Massachusetts
Ok update #2:
I put the front pads and rotors on today. Boy does it brake smooth as ice now. Perfect stopping. So to answer the original question of this post, it was pads and rotors, front and rear.
Also when I went to take the rubber sleves off the pins, one of them had gotten jammed up to the head of the pin. A lot of good that was doing!
So the brakes feel great. But with new pads, rotors, and freshly greased pins, it was obviously going to feel great. The breaks feel more responsive, and it *feels* like the front are engaging easier, so thing are more balanced under light braking. Heavy breaking always worked great.
^but who knows how much of that is real and how much is in my head.
Also when I took the front rotors off, both rotors had clean, smooth outer braking surfaces, but the inner surface was very pitted and rusty on both sides. Suggesting that those rubber pin sleeves were really causing problems. At least that's how I interpret it.
If there is any negative side effect from removing those sleeves, I'll try to remember to come back to this thread and update. But as of right now, it's mission accomplished.
Oh and regarding pricing, the front pads and rotors were from rockauto as a kit and they were $165 shipped.
I got the rear pads and rotors at NAPA with local pickup and a "20% off sale" for $155.
All four rotors were coated.
l008com
902
Massachusetts
Oh I did have one more question. When I clamped the second caliper all the way open, apparently it looks like some brake fluid leaked out from the reservoir in the engine and leaked back down on to the driveway. Is that normal? Is that... ok?
Chadla11
